Floating point exception using RSM model
Old   November 20, 2012, 22:19
Default Floating point exception using RSM model
Jorge Tamayo
Jorg is on a distinguished road
Hi, i'm trying to simulate a Circulation control airfoil using the Reinolds Stress Model but I have no experience with it; could anybody giveme some guidelines to get my simulation running?
Jorg is offline   Reply With Quote
Old   November 21, 2012, 03:54
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Does your simulation converge with some less complex turbulence model (k-epsilon...)?
PS: RSM behaves like a diva...
RodriguezFatz is offline   Reply With Quote
Old   November 21, 2012, 18:14
Jorge Tamayo
Yes, it converges and behaves well when using k-omega or Spalart Almaras. I think i'm gonna need a very precise setup of the RSM inputs....
Old   November 22, 2012, 05:22
Philipp
Hey, I am no expert in RSM, but I have a little experience just by trying different turbulence models: In my cases (2d, axisymmetric) the RSM always needed much more cells to work than all other models. Also, I had a few cases, when I never got the RSM working. In your case, I would start by trying to get reasonable values for the RSM boundary conditions at the inlet. If this doesn't work, you could refine your mesh to some unimaginably superb degree and see if that works...
Old   November 22, 2012, 08:23
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
It requires higher mesh quality specially cell aspect ratio (~10 or less)
See this thread for details http://www.cfd-online.com/Forums/cfx...nvergence.html
Far is offline   Reply With Quote
Old   November 23, 2012, 12:39
Jorge Tamayo
thanks for your help, i'll try to get higher mesh resolution and let's hope it works. Im concerned about the amount of elements i'll have to define in the flow direction of the boundary layer region to achieve such AR values...
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 10:31
Error : floating point exception; overflow. maryam CFX 3 May 18, 2010 07:44
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
