Dissappearing/Missing Boundary Type, What Happened?
Old   March 21, 2013, 11:22
Default Dissappearing/Missing Boundary Type, What Happened?
spincfd is on a distinguished road
Why my Fluent 6.2.16 misread the boundary type?
I am sure I already specify the boundary type correctly in my Gambit 2.2.30.
But why when analyzed in Fluent 6.2.16, some of these boundary types are missing?
spincfd is offline   Reply With Quote
Old   March 22, 2013, 09:18
Paritosh Vasava
vasava will become famous soon enough
Can you explain more about your problem. What exactly are you simulating? Which type of boundary and to which type they are converted?
vasava is offline   Reply With Quote
Old   March 22, 2013, 11:45
I am simulating a wind motion passing an aerofoil inside the wind tunnel.
I create the geometry of the wind tunnel as a 2D rectangle in Gambit.
And the 2D aerofoil is inside the rectangle.
I specify the boundary types as below:
left edge of the rectangle is a velocity inlet.
right edge of the rectangle is an outflow.
top and bottom edges of the rectangle is wall.
Why Fluent don't show these boundary types?
There are only two option from the "solution initialization" drop down menu (solve > initialize > initialize...), all zones and wall.
Also, I can't find all of the four boundary types I already specified earlier in the Gambit, under the Zone of the Boundary Conditions (Define > Boundary Conditions...) instead of default-interior, fluid, and wall.
Note that I am using Fluent 6.2.16
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 08:07
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 07:32
Boundary condition setting for non-premixed combustion using reactingFoam skyopener OpenFOAM 0 May 23, 2010 22:55
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
