droplet falling - VOF
Old   January 13, 2009, 12:40
Default droplet falling - VOF
bohis
Hi there, I have the following problem: I am simulating water droplet falling in the air and perpendicularly impacting on plane surface. The model is axisymmetric, the initial droplet velocity is zero, so only gravity and surface tension forces acts on droplet. If the droplet diameter is of 2mm, than there is no problem with simulation. Even different grids give similar results of a droplet velocity developing. On the other hand, if the droplet diameter is of 0.2mm, the droplet is falling, but there is significant velocity fluctuation (even negative values of velocity, which I expect not to be possible) For the finest mesh (0.0025mm), the droplet(0.2mm) keeps fluctuating around initial velocity condition (zero m/s) and seems to never fall down. Where could be the bug? I do not believe that it is connected to my very fine mesh. (I am using both CICSAM and HRIC vof discretization schemes) (local CFL always lowere than 0.5)
thanks for any help!!!
Old   July 10, 2013, 04:28
otsigun is on a distinguished road
I am also working on similar Project on wetting Dynamics of an indium droplet. Can you send me your files, so that I can recommend something mehmet.yigit.balta@gmail.com
otsigun is offline   Reply With Quote
CFD for falling film evaporator Binglu Ruan FLUENT 11 March 11, 2020 12:51
falling drop ozgur FLUENT 6 October 23, 2012 03:56
Falling Droplet Boundary conditions feijooos OpenFOAM Pre-Processing 0 November 20, 2008 12:33
Falling sphere Graham FLUENT 10 April 25, 2008 13:02
falling of ball in water nabeel mohsin FLUENT 2 November 26, 2004 05:50
