November 26, 2012, 11:05 |
Temperature variation
Mohamed
Rep Power: 13 |
I need to see the temperature variation vs time at a certain point.
When i create a surface (point) monitor with mass weighted average, the plot shows a line goes horizontally at zero, and doesn't show any temperature curves vs time. Please tell me what to do |
November 26, 2012, 22:19 |
Lucky
Rep Power: 66 |
It is because you are computing a surface integral. A point has 0 surface area, so it will always report 0 to all quantities.
You should use either vertex minimum, average, maximum, or facet minimum, average, or maximum to retrieve values of points. |
December 10, 2012, 06:38 |
Mohamed
Rep Power: 13 |
Thank you lucky tran
UDF temperature variation | Alex E-H | FLUENT | 3 | February 19, 2017 14:55 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Pressure temperature variation | Dev | CFX | 0 | June 21, 2007 23:01 |
Viscosity variation with temperature for gases- | Kedar | Main CFD Forum | 3 | October 24, 2005 06:43 |
variation of surface tension with temperature | Markus | FLUENT | 1 | July 17, 2002 20:23 |
