fluent autosave?
Old   February 8, 2013, 03:24
Default fluent autosave?
Thomas Hoffmann
Thomashoffmann is on a distinguished road
Hi
I'm running Fluent through workbench. If I run a simulation for 100 iterations and save before I close fluent and then open fluent again, then the calculations are not saved. Even though I click save project before I close fluent, it only saves the setup and not the iterations that I carried out before I closed fluent last time..
Anybody who knows how to make it save properly, so I can do further iterations when I open up fluent?
Thanks
Thomashoffmann is offline   Reply With Quote
Old   February 8, 2013, 05:05
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
You only save the case file, but you need to save the results, too. I don't know if you can reload the last state automatically, but you can autosave the data every x-iterations.
When restarting, click on file->import->data.
Good luck.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 07:46
On Autosave Fluent Hangs nirupam FLUENT 1 September 6, 2007 14:06
Fluent 5.2.3 autosave? Ricky Wong FLUENT 1 March 24, 2000 15:36
