February 13, 2013, 18:10 |
plotting question
Right now I have a certain mesh size. I would like to decrease the mesh size and increase the mesh size to determine when the flow becomes mesh independent. To deteremine this I want to plot the velocity at a certain point vs. the number of iterations or mesh size. Is there a way to do this or is there a better way to determine if the flow is mesh independent?
February 13, 2013, 22:36 |
If you want to do mesh independent study. Refine the mesh. Solve it . Then go back and refine further and then solve again. Compare the solutions. If solution changes. Refine and solve again. Then compare. Repeat the process until the solution does not change with refinement i.e mesh independent solution
February 13, 2013, 23:35 |
What do you mean by solution? I can plot the pathlines of the flow but there are too many to compare and it is difficult to see if they are similar or not. What would you recommend I try?
February 14, 2013, 00:11 |
It depends on your problem . What are you trying to solve ?
Anyways, let take an example. Say if you want to find a velocity. Plot a velocity contour or plot a XY plot along a set of points (line) and see if they change with the grid refinement. |
February 14, 2013, 00:31 |
I am analyzing the flow of air in a room with different inlets and outlets. Right now I have a quarter of a symmetric room with two of the sides as symmetry and the others are walls. Eventually I am going to add different particles and see how to move with the flow and how long they take to exit the room.
February 14, 2013, 00:35 |
thanks for your help. I'll try your suggestions tomorrow.
Contours of 2D plotting | therockyy | FLOW-3D | 4 | December 22, 2012 15:04 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
question about horizontal oscillation of naca0012 | Du | Main CFD Forum | 3 | May 10, 2001 07:39 |
