January 27, 2023, 18:58 |
Initial Static pressure calculation
Rep Power: 3 |
Hello everyone,
I am using a inlet velocity on a pipe in order to verify my pressure drop but I am not sure how Ansys calculates the Initial static pressure in order to solve the problem. Does anyone know? Best regards |
January 27, 2023, 19:08 |
Lorenzo Galieti
Rep Power: 12 |
if you impose a velocity at the inlet, the inlet pressure is a result of the problem. It depends on your outlet pressure (which you impose) and the pressure drop that the CFD predicts.
ansys, fluent |
Compressible flows with larger Courant numbers | Tobi | OpenFOAM Running, Solving & CFD | 5 | February 26, 2021 15:20 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
Recursive output of Foam::word in gdb print command | chengdi | OpenFOAM Programming & Development | 1 | July 19, 2017 20:19 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
