Design and heat transfer analysis of condenser
Old   April 3, 2018, 14:07
Red face Design and heat transfer analysis of condenser
Naresh Mahendran
nareshzeeda1994 is on a distinguished road
Hi all.
I'm new to fluent. I need to design the geometry of the condenser such that I can be able to solve it in fluent. The condenser is 4 pass heat exchanger which consisted of 14 tubes in 1st pass, 7 tubes in 2nd pass, 6 tubes in 3rd pass, 4 tubes in 4th pass.
I need to solve both the streams ( primary and auxiliary fluids )
How to design it through porous medium and how to simulate it in fluent ???
It does have phase change ability. So how to give phase change in ansys ?
Please help....
Thanks in advance
nareshzeeda1994 is offline   Reply With Quote
Old   April 28, 2018, 09:50
Unhappy Need help in simulating a condenser
Naresh Mahendran
Hi all,
I'm new to Fluent. I'm trying to simulate 4-pass condenser. It involves phase change also.
I'm doing it by porous medium method.
I have attached the dimensions of one set. Like that, there are 36 set.
1st pass - 16 tubes
2nd pass - 8 tubes
3rd pass - 7 tubes
4th pass - 5 tubes
Need all your help in designing and simulating it.
Thanks all.
condenser, multi pass, phase change
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 04:07
star design - to model heat transfer gagi Main CFD Forum 0 November 11, 2011 01:41
Modelling the heat transfer during compression and cooling of natural gas pano Main CFD Forum 0 December 10, 2010 15:53
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
