rotation in Fluent
Old   March 8, 2013, 11:59
Default rotation in Fluent
Arty is on a distinguished road
Hi, guys. Here is the question:
I'm making a 2way FSI analysis considering a gas compressor blade. So, I have a mesh for the blade used in Transient Structural and another mesh for the blade domain used in FLUENT.
I inserted rotational velocity for the blade in the transient analysis and not sure, must I input this value of velocity for the mesh in FLUENT or rotation is not essential for Fluent.
Arty is offline   Reply With Quote
Old   March 11, 2013, 16:14
stumpy is on a distinguished road
A rotational velocity in Transient Structural applies the forces due to rotational motion, but it does not actually rotate the mesh. So the displacements passed to Fluent are just the relative deformations due to rotational forces (and fluid forces I assume). The mesh in Fluent should not rotate either so that it remains aligned with the structural side (i.e. do not use a sliding mesh approach in Fluent).
In the transient structural case are you ramping up the rotational velocity? If not, then that means the rotational forces are applied instantaneously at the start of the transient. How will the structure respond to this?
stumpy is offline   Reply With Quote
fluent, fsi, rotational velocity
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
