journal file - problem in initialization
Old   March 27, 2013, 14:46
Default journal file - problem in initialization
Mohammad Reza Hadian
hadian is on a distinguished road
i want to create a small journal file to
1- read case and data
2-initialize a surface (which is my air inlet and the name is air_inlet)
3- do the iteration
4- save the case and data
5- exit
here is my journal file. but it does not work well and give me an error in initialization part.
/file/read-case-data /home/hadian/1.cas
/solve/initialize/compute-defaults/air_inlet
/solve/iterate 10
/file/write-case-data /home/hadian/2
yes
/exit yes
/exit
/quit
hadian is offline   Reply With Quote
Old   March 28, 2013, 02:36
blackmask will become famous soon enough
It seems that the command for 2 is missing, see below. I have a vague impression that FLUENT will initialize the flow automatically upon iteration. But you should try to manually add this line to check whether it makes any difference.
3- do the iteration
5- exit
ONE LINE MISSING HERE
/solve/initialize/initialize-flow
/solve/iterate 10
yes
/exit yes
/exit
/quit
blackmask is offline   Reply With Quote
Old   March 31, 2013, 05:38
it seems that the command "/solve/initialize/compute-defaults/air_inlet" does not initialize on air_inlet surface. i do not know if the command is correct it something should be add to it!!!
Old   March 31, 2013, 20:54
/solve/initialize/compute-defaults/velocity-inlet air_inlet
if you name your inlet boundary "air_inlet"
Old   April 1, 2013, 02:16
this is the result:
> /solve/initialize/compute-defaults air_inlet
invalid command [air_inlet]
so there is something wrong!
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
