Simulating movement of air from low to high pressure in Fluent
Old   April 11, 2013, 04:18
Default Simulating movement of air from low to high pressure in Fluent
James Willie
jwillie2000 is on a distinguished road
Hello Everyone,
I am looking at duct in our pump and I want to simulate this duct. The problem is that the inlet region is at a lower pressure relative to the outlet. The flow is also compressible. So I am thinking whether this can be easily done in Fluent? I tried using the outflow boundary at the outlet and a mass flow inlet but this does not work when the flow is compressible. Any suggestions would be appreciated.
Thanks!
Jimmy
jwillie2000 is offline   Reply With Quote
I am NOT getting right pressure at the air inlet in water column kcfd FLUENT 2 November 27, 2012 21:36
Simulating a pressure pulse in Fluent sachinthakre FLUENT 0 October 25, 2011 09:27
Simulating a high pressure flow through a valve Kromagnsss FLUENT 8 July 2, 2010 05:20
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
Fluent 5.2, UDF and Pressure BC's Alfonso Ferrandez FLUENT 0 May 4, 2000 07:02
