June 11, 2014, 09:31 |
Changing the properties of a fluid
Rep Power: 11 |
Dear experts,
Since I want to be able to simulate blood flow, I thought of taking an arbitrary fluid from Ansys database, and change its properties to the properties of blood. The problem is that when trying to do this, I saw I could not change any property except from density and viscosity. Is there any way to change the other properties of a fluid in Fluent? if not, is it necessary to make a udf for this purpose in order to simulate blood flow (I want to consider blood as a Newtonian fluid)? Thanks in advance |
June 11, 2014, 09:42 |
Flavio
Rep Power: 15 |
Hello ForumLord,
you can activate the properties of the materials only after activating some models in Models Menu (for example Energy for Conductivity and Specific Heat, the same for Multiphase, etc...) Regards
Bionico |
June 12, 2014, 01:25 |
Rep Power: 11 |
Hi Bionico,
Thanks a lot for your answer. I will try it and if something still won't work, I will reply here again. |
blood flow |
Changing Polynomial Properties of species from 8 to 16 coefficients | Kenna | OpenFOAM Programming & Development | 1 | November 20, 2013 03:44 |
Require the fluid properties of the following fluids at different temperatures | rohitjvbibin | Main CFD Forum | 0 | October 21, 2010 05:56 |
STAR INTERNAL FLUID PROPERTIES ? | Wael | Siemens | 5 | March 7, 2006 19:11 |
Material properties for fluid and solid | David Baker | Siemens | 0 | August 26, 2003 01:57 |
Intl Conf Computational Methods in Fluid Power | Jacek Stecki | Main CFD Forum | 0 | November 10, 2002 05:49 |
