output power of wind turbine
Old   May 16, 2013, 11:23
Default output power of wind turbine
niloogh is on a distinguished road
hi
I had simulated a wind turbine using fluent and I want to calculate the output power(mechanical power) of it in different wind speeds .
I don't know how to evaluate the output power.
would you plz help me??
niloogh is offline   Reply With Quote
Old   May 16, 2013, 20:22
blackmask will become famous soon enough
Power = Torque*omega.
Assume the axis of the rotor is in the z-direction, and you set the origin at the axis of your rotor, then torque is the z-moment. The omega is angular velocity you specified for the rotor.
blackmask is offline   Reply With Quote
Old   May 17, 2013, 11:03
tnx a lot dear
it was really useful for me.
i have another problem which my moment amounts are negative!!!!
my flow comes from y- to y+
i had set my velocity inlet -11
and my rotation direction is +y
would you plz help me???
Old   May 24, 2013, 15:34
hi dear
i have got smaller amount for my simulation using your formula mentioned above.
all of them are 100 order smaller:
46kw in stead of 4600kw
would you plz help me to find the reason.
Old   May 28, 2013, 05:26
s.q
s.q is on a distinguished road
hi blackmask
i,m using the way that you mentioned in this forum but my results are about 10 times bigger than the exact amounts.
i really need help.would you plz guide me???
s.q is offline   Reply With Quote
Old   May 28, 2013, 07:31
Then the power coefficient should exceed the Betz limit. Make sure that the angular velocity is expressed in rad/s rather than RPM.
Old   May 28, 2013, 08:17
s.q
my angular velocity is in rpm and i set it in units panel too.
where can i change the cp in fluent????
or how can i totally reduce cp ??????
Old   May 28, 2013, 08:34
OK. Tell me your RPM, aerodynamic torque and the rated power of the wind turbine. If your result is reasonable then you might calculate your power with the wrong unit for ten is closed to 60/(2 pi).
Old   May 28, 2013, 08:38
my rated power : 5 MW
torque in fluent: 51084019 nm
ang velocity:12 rpm
Old   May 28, 2013, 08:43
s.q
ang velocity:12 rpm
Old   May 28, 2013, 08:45
Are you sure? The aerodynamic torque is 5.1E7 N.m.
T=5.1E7
omega = 12*2*pi/60 = 1.2566
P = T*omega = 64.2 MW
What is your rotor diameter, rated velocity and the velocity your used in your computation?
Old   May 28, 2013, 08:50
s.q
T=5.1E7
i have this torque from:report-forces-moment-moment center(0,0,0)
rotor diameter:63m
rated wind velocity:11m/s
rated ang velocity and my rotational velocity :12rpm
Old   May 28, 2013, 08:51
s.q
T=5.1E7
i have this torque from:report-forces-moment-moment center(0,0,0) total moment in y direction
rotor diameter:63m
rated and velocity and my rotational velocity :12rpm
Old   May 28, 2013, 08:53
What is the location of your rotor shaft?
Old   May 28, 2013, 08:56
s.q
the center of hub is located at (0,0,0)
the blades rotate around y axis
i imported geometry from gambit
Old   May 28, 2013, 09:17
s.q
do you have any idea about this problem?
any suggestion
Old   May 28, 2013, 09:27
Maybe your computation does not converge. Please check your converge history. If possible please post a contour plot of axial velocity on a slice at the hub height.
Old   May 28, 2013, 09:42
s.q
this are photos of my residuals and velocity contour
in addition mass flow rate difference between inlet and outlet is 250 kg/s when the total inlet mass flow is 693639.75 kg/s
axial velocity contour in y=0 plan
Old   May 28, 2013, 09:47
Please monitor the force and moment of your rotor and continue calculation until the force and moment converge.
Old   May 28, 2013, 13:58
s.q
hi blackmask
i had done what you told.
please take a look at this photos and check if my solution is converged or not.
in this situation the torque is 44944300
Compute the power of small wind turbine. Luolin FLUENT 9 May 27, 2013 14:52
shaft power versus RMP curve in wind turbine simulation zhenduan306 CFX 28 November 8, 2012 10:11
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
Wind Power Frank Grassi FLUENT 0 October 12, 2007 11:20
about wind turbine power prediction with cfd windman FLUENT 1 January 11, 2007 06:41
