B.C Pressure inlet/outlet
Like Tree1Likes
  • 1 Post By mohamed rabie
Old   June 12, 2013, 08:31
Default B.C Pressure inlet/outlet
Omar
omar87st is on a distinguished road
Is there any difference between a pressure outlet/inlet if we set it to 0 Pa?
I have a case where the calculation converge way better when i change a pressure outlet (0Pa) to pressure inlet (0Pa)
Thank you.
Omar
omar87st is offline   Reply With Quote
Old   June 14, 2013, 10:13
delaneyluke is on a distinguished road
You'll have to be more specific. What are you modeling? What is driving your flow if your pressure differential is zero?
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   June 14, 2013, 15:26
Omar
Thanks for answering, i have 2D wind tunnel car simulation with a vellocity inlet and all the others edges are: walls -> for the car, and pressure outlet for all the others .
The think is when i run the calculation like that it does not converge verry good "the continuity does not"
And when i replace one of the edges from pressure outlet "0Pa" to pressure inlet "0Pa", the model converge verry well and verry fast...
Thanks
Omar
Old   June 16, 2013, 06:56
Yaser
Barzanoni is on a distinguished road
Hi
if the other boundaries are something like as free stream ( or pressure far fild in the compressible flow), the pressure inlet with 0 Pa lead to better and faster convergence. I had some experience like this.
You should be care about no entering flow from these boundaries.
Barzanoni is offline   Reply With Quote
Old   June 16, 2013, 14:48
Omar
Hi, Thanks for answering
I only have pressure outlets and a vellocity inlet ...
I don't know why it's happening, i will take it as a rule until i find the difference between the pressure inlet/outlet at 0 Pa !
Thanks
Omar
Old   June 17, 2013, 15:55
A pressure inlet/outlet at 0 Pa is technically the same (differs by direction of flow). You have to make sure that you do not have air entering in through the pressure inlets.
The reason your simulation works well with the pressure inlet and not the outlet is cause there might be air entering your domain from these surfaces.
Do you get a lot of reversed flow when you pressure outlets?
Alternately you could use the farfield BC's, which are meant for your kind of problem
Regards
Luke
Old   July 13, 2013, 18:53
mohammed rabie
mohamed rabie is on a distinguished road
hi,
when you set the B.C as pressure inlet, it is total pressure
but when you set it as pressure outlet it is static pressure
mohamed rabie is offline   Reply With Quote
Old   July 14, 2013, 08:32
FHydro
flow_CH is on a distinguished road
Originally Posted by mohamed rabie View Post
hi,
I don't think so. Total pressure= static pressure+dynamic pressure and absolute pressure=gauge pressure+operating pressure. Every time we use the gauge pressure=0, it means that absolute pressure=operating pressure and it means, the outside of boundary is atmosphere(if we use the default for operating pressure=101325 pa)
flow_CH is offline   Reply With Quote
Old   July 19, 2013, 18:49
mohammed rabie
mmmmmm,
no problem at all, it is right, but the default in fluent is to take the pressure inlet value as total, but take the pressure outlet value as static , you can take a view in the fluent user guide.
and kindly please reply me,
I will wait for your reply
thanks
sbaffini likes this.
boundary conditions, fluent, pressure
out flow and pressure inlet B.C mohsen.es FLUENT 0 December 6, 2011 09:42
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 17:19
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
