LES w/ no SGS
Old   June 20, 2013, 08:54
Default LES w/ no SGS
amanbearpig is on a distinguished road
Is there an easy way to implement LES with no subgrid-scale model in Fluent? I have looked through the GUI and TUI and cannot seem to find a way to do this.
amanbearpig is offline   Reply With Quote
Old   June 20, 2013, 09:03
OJ
oj.bulmer will become famous soon enough
If you do not want to use SGS models, how will you model the non-energy containing small eddies?
OJ
oj.bulmer is offline   Reply With Quote
Old   June 21, 2013, 05:49
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Of course there is, it is just the laminar model under viscous model. Also, you can use a static Smagorinsky model and set the constant Cs to 0.
I would prefer the first one (much less costy); in this caase, however, in order to activate the second order central scheme you need to use the TUI:
solve->set->expert
and activate all the available schemes.
Whether or not the model is useful or necessary depends on a lot of factors, including, of course, which model and which numerical schemes you are using. More often than not it is almost useless in Fluent (even with a pure, unbounded, central scheme). This is mostly because of the eddy viscosity models and the Fluent features, but it is somehow difficult to explain briefly here.
For a complex application i would rather just select the bounded central scheme and no model at all (An approach also known as ILES).
Of course if you're in model development, you can actually work on specific issues and let the model do what those in Fluent can't.
Check this reference for a sensitivity on SGS model and numerical scheme in Fluent:
http://www.lamc.ing.unibo.it/aimeta2.../MEM-273-0.pdf
sbaffini is offline   Reply With Quote
How to access the subgrid-scale (SGS) stresses with LES (FLUENT) ? Marvin FLUENT 0 May 12, 2011 12:13
how to do in dynamic subgrid sgs les model? aiya Main CFD Forum 2 September 15, 2006 01:45
How to the taw(kk) in Les SGS model? aiya Main CFD Forum 0 August 11, 2006 10:21
Which SGS viscosity model is most popular in LES? leaf Main CFD Forum 1 August 1, 2006 05:04
LES: SFS or SGS jose Main CFD Forum 2 June 8, 2004 06:22
