Import data problem ANSYS workbench
Old   February 23, 2016, 04:28
Question Import data problem ANSYS workbench
Gowain
eaglemckenna is on a distinguished road
I need to understand how the nodes in my mesh are connected. I am exporting data from FLUENT in ASCII format and it is important I understand how the structure of the mesh is ordered.
I using this data to form a reduced order model of a CFD RANs solution within MATLAB, the algorithm does not change the structure ASCII structure.
  1. I am wanting to then import the approximated solution data from MATLAB which still has the ASCII format back into the results tab in ANSYS WORKBENCH for post processing and rigorous error analysis.
    I do hope some of you can be of help.
    best wishes
    g
eaglemckenna is offline   Reply With Quote
import problem
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
Import Mesh Problem: New to Ansys EphemeralMemory ANSYS Meshing & Geometry 6 July 24, 2015 05:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Ansys 12 Workbench problem when generating volume mesh Sveink ANSYS 5 January 6, 2010 03:17
Problem of import fluent data to ilight fieldview seasoul FLUENT 3 September 9, 2008 22:36
