Whats the difference between Sliding Mesh and Dynamic Mesh?
Like Tree5Likes
  • 4 Post By blackmask
  • 1 Post By Vandeley
Old   July 14, 2013, 16:02
Default Whats the difference between Sliding Mesh and Dynamic Mesh?
Arthur Loginow
Maralady is on a distinguished road
I have been reading the users guide, but I do not understand the difference between the Sliding and Dynamic Mesh, can someone help me? Please
Maralady is offline   Reply With Quote
Old   July 14, 2013, 21:05
blackmask will become famous soon enough
The simple answer is, the cell shape is changed in dynamic mesh but not in sliding mesh. The dynamic mesh is flexible, computational time consuming, and error prone.
soheil_r7, Jiss, iamyou and 1 others like this.
blackmask is offline   Reply With Quote
Old   July 14, 2013, 21:27
Arthur Loginow
Thanks, I am trying to simulate the following geometry, 2 propels inside a pipe, but the problem is the cellzones, so far I understand that to simulate those shapes I need to use REMESHING therefore Dynamic Mesh, is this correct??
Both propels will be rotating
Old   July 14, 2013, 21:55
If the distance between propellors is bit larger you might have a chance to use sliding mesh. For now I am afraid you have to use dynamic mesh. The dynamics mesh might work well because the geometry seems to be simple.
Old   July 14, 2013, 22:00
Arthur Loginow
Yes the idea is to work with a cell zone that it is not regular and shares some space with the other cell zone, like in this case both cell zones shares a small common area, it is just a simple test to work on a more complicated simulation (twin screw pump), thanks for your answers and please let me know about your opinions too
Old   May 25, 2015, 01:51
Default sliding mesh vs dynamic mesh
chigs
chirag.palan1987@yahoo.in is on a distinguished road
please tell more about sliding mesh and dynamic mesh
i am very new to cfd want to know more
thanx
chirag.palan1987@yahoo.in is offline   Reply With Quote
Old   May 25, 2015, 07:20
D. B.
Vandeley is on a distinguished road
The sliding mesh motion can only have a constant rotating velocity.
For the dynamic mesh, a new angular velocity is calculated during each time step based on the viscous and pressure forces acting on the region.
So if you have a problem where the parts are dependent on the fluid flow you should use the dynamic mesh.
If your region is rotating with rigid walls, the mesh should never deform and thus there is no need to remesh during the time steps.
Vandeley is offline   Reply With Quote
Old   May 25, 2015, 08:23
chigs
thanx for information
i am having simple cylinder in the flow domain and i want to know the time history of the cylinder motion during the flow ca you help me in doing that
Old   May 25, 2015, 09:33
D. B.
If you enable the dynamic mesh, you have the option to write the motion history.
Dynamic mesh -> Options, Settings -> Write Motion history.
Then you will get a .out file in your working directory with the angular velocity during each time step.
Old   May 26, 2015, 01:16
chigs
thanx for reply
i will try that option
regards
Old   March 11, 2016, 12:15
Default moving mesh
  #11
navid toussi
navidmt is on a distinguished road
Hey guys , I have a question regarding moving mesh, I never had experience on this topic, actually I'm modeling an air jet nozzle in which a high pressurerized air goes into a T shape pipe channle , dimentions of these pipes are in MM.
as we don't have any heat exchanging through the wall so I just modeled the fluid zone inside the pipes,
my supervisor asked me to model it with moving mesh, and I have no Idea how can i do it
navidmt is offline   Reply With Quote
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 10:08
sliding mesh ? airfoil dynamic stall? xiaomi FLUENT 2 March 18, 2013 05:42
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 23, 2010 23:53
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 02:37
