September 19, 2010, 02:37 |
Torque calculation of 2D VAWT Wind Turbine
Rep Power: 16 |
Hello Everyone,
I am working on my Thesis which is basically 2D CFD simulation of Vertical Axis Wind Turbine. I need to calculate the torque generated by a wind turbine in order to find Cp. In this regard I am running 2D simulation with sliding mesh technique and saving the case/data file after every 10 degrees of rotation hence I have 36 files for one complete revolution. Now I am reporting the value of forces in X and Y direction (Fx and Fy) from each case/data file for all 3 Blades. Then I calculate Torque on each blade using formula T1 = - Fx1.RcosΘ - Fy1.R.sinΘ T2 = -Fx2.Rcos(Θ+120) - Fy2.R.sin(Θ+120) T3 = -Fx3.Rcos(Θ+240) - Fy3.R.sin(Θ+240) Total Torque T = T1 + T2 + T3 (Total Torque “T” is calculated for every 10 degree of rotations) Average Torque = Σ T/n (0-360 degrees) where n = 360/10 = 36 Please let me know if the method I am using is correct. I am confused about the sign convention of Torque equations. is there any other way to find out Torque and Cp(Coefficient of performance)? Last edited by jola; January 5, 2012 at 11:02. |
September 20, 2010, 01:15 |
Maxime Perelli
Rep Power: 41 |
in Fluent you can compute moments (torque)
Report/Forces... choose Moments instead of Forces.
In memory of my friend Hervé: CFD engineer & freerider |
September 20, 2010, 19:57 |
Rep Power: 16 |
Thanks for your reply. I tried to report the moment in fluent but its all negative. is it cuz my Turbine is rotating in counterclockwise direction? do I have to sum them all up to get the total torque (M= M1+M2+M3) for angle 0-360 degrees?
Thanks |
September 21, 2010, 02:31 |
Maxime Perelli
Rep Power: 41 |
If you compute the moment you should give the right axis.
if you set the angular velocity, you should give the right direction (axis-convention) And yes, if all your moment are computed on the same point, you can add them
November 20, 2010, 10:06 |
Asking for help!!
Low Chee Boon
Rep Power: 15 |
Hi , friend ! im new for Fluent, i also want to get the data from VAWT after simulation. but i dont know how to build up 2D drawing in Fluent. Can you guide me how to build it up in fluent ?
August 27, 2011, 01:42 |
#6 | |
Hi Max, how are you? i hope that you are well i simulated 2d VAWT successfully with OF (ggi method) and get the good result for mummentum as expected. after that i decide to simulate it in 3d Geometry. so i create the 3d geometry and Mesh in Gambit and import it to OF, every thing is ok and i stop the run after 50 rotation degrees. when i see contours of velocity or pressure, every things is ok, but when i extract the mummentum, the result is very bad!!!??? why this happen??? for calculate the forces and mummentum for every blade i added similar code in controlDict file : forces_1 { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 100; patches (Blade1); PName p; Uname U; log true; rhoInf 1.2; CofR (0 0 0); ______ Rasoul |
August 29, 2011, 01:42 |
Maxime Perelli
Rep Power: 41 |
adapt CofR (0 0 0) coordinates.
They are needed for torque computation
August 29, 2011, 04:07 |
How to adapt CofR (0 0 0)? i set it at center of rotating object
August 29, 2011, 04:08 |
#9 |
_____ Rasoul |
August 29, 2011, 04:12 |
#10 |
Maxime Perelli
Rep Power: 41 |
It should be the a point on your rotation axis
August 29, 2011, 04:36 |
#11 |
would you mind to seee this froum(from post 8):
http://www.cfd-online.com/Forums/ope...tml#post322023 i set my result for 2D and 3D VAWT and case in it. i think that i chose the point on the rotation axis ______ Rasoul |
August 29, 2011, 04:47 |
#12 |
Maxime Perelli
Rep Power: 41 |
do you think or are you sure?
If you go back to your mesher, check if (0 0 0) belong to your rotation axis.
August 29, 2011, 05:23 |
#13 |
now i am surely chose the point at the center of axis. i check it witj mesher and paraview? did you see my result and pic that set in the mentianed froum in the last post?
_______ Rasoul |
August 30, 2011, 04:48 |
#14 |
Maxime Perelli
Rep Power: 41 |
check if pressure distribution on blades are the same on 2d and 3d
September 26, 2013, 03:35 |
#15 |
Michael Bausas
Rep Power: 13 |
Anonymized_JL1, good day! I am also working on a three bladed VAWT for my thesis.. I am currently building my gemometry and mesh using ICEM CFD. I started with a 1/3 portion of the turbine and had generated its unstructured mesh.. Do u have any suggestion on how to go on with my meshing from this point? How shall I generate the other two parts and how to merge them into a whole rotor. Please help. Thanks in advance..
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) | tony00 | FLUENT | 11 | July 23, 2018 06:13 |
Torque of wind turbine simulation | caohan | FLUENT | 8 | August 11, 2014 23:01 |
VAWT Wind Turbine | Tom Smith | FLUENT | 11 | August 27, 2011 01:38 |
help to find torque of a wind turbine using fluent | athiyaman.p | FLUENT | 1 | March 10, 2006 10:49 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
