cooling of the brass plate
Old   October 1, 2013, 07:07
Default cooling of the brass plate
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
HI every one
I'm trying to simulate the below problem
large brass plates of 4-cm thickness that are initially at
a uniform temperature of 20
C are heated by passing them through an oven
that is maintained at 500
C. The plates remain in the oven for a
period of 7 min. Taking the combined convection and radiation heat transfer
coefficient to be h  120 W/m2 ·
C, determine the surface temperature of the
plates when they come out of the oven.
answer for this problem is 282 C.
Which boundary condition in fluent should is use
kiran is offline   Reply With Quote
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 07:07
2D cooling of wavy plate Vidit Sharma FLUENT 9 August 15, 2012 08:24
HELP! Flow over both sides of a plate. farocean97 Main CFD Forum 0 September 12, 2011 10:57
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 15:15
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 11:49
