September 14, 2017, 09:40 |
coil tank
saba
Rep Power: 8 |
hi every body
please I have reearch about the natural convection heat transfer from helically coiled tubes under constant wall heat flux density, with vertical axis in water was carried out. The effect of helix diameter and helix pitch on the local and average Nusselt number have assessed. A complex influence of the two parameters on Nusselt number must be found. The heat transfer device was immersed in a cylindrical enclosure with vertical axis. The proximity of the wall enclosure must be found to influence the buoyancy induced flow profile and as a consequence, Nusselt number value. d of pipe =0.02m D of coil=0.16 m Pitch=0.05 m Diameter of tank =0.6 m No. of turn=9.5 coil inside tank My question how Can I solve the model because I solved it in Fluent , CFX, and comsol but I didnt have any result I need to advice me what should I do Thanks |
Need Help! High pressure Gas discharge from tank to tank through a pipe | superarthur86 | FLUENT | 2 | June 16, 2017 10:22 |
Tank refuelling simulation | Bisht | STAR-CCM+ | 4 | July 30, 2015 11:02 |
error messages about blockmeshing and solving | cramsdead | OpenFOAM Pre-Processing | 2 | November 11, 2014 10:53 |
Mixture and Decay of a tracer in a Water Tank | Jeffrey1992 | CFX | 2 | July 27, 2012 13:31 |
Blow Tank Simulation ... Need Help! | treyevans | CFX | 1 | February 20, 2010 00:42 |
