Pressure gradient through vertical pipe
Old   November 18, 2013, 17:07
Default Pressure gradient through vertical pipe
Aileen Magee
0906536m is on a distinguished road
Hello there,
I am trying to simulate flow of a fluid through a vertical pipe. The fluid properties depend on pressure. The inlet of the pipe is a velocity inlet with a pressure of 0Pa. The outlet is a pressure outlet at 80Pa. I am wondering why I do not get a linear pressure gradient along the pipe as pressure should increase gradually as you travel down the pipe. Instead on plotting pressure contours I get results that the whole pipe is at 0Pa apart from the very outlet boundary. Could anybody explain why this is?
Thankyou
0906536m is offline   Reply With Quote
vortex cause pressure gradient or pressure gradient induce vortex? fruitkiwi Main CFD Forum 4 June 12, 2012 01:12
how to get pressure and pressure gradient using UDF Honglin Fluent UDF and Scheme Programming 0 May 24, 2012 06:47
How to find the reflections of the pressure wave in pipe lines RKR Main CFD Forum 0 April 6, 2011 08:08
How do i measure pressure gradient along a pipe? mayur_ Main CFD Forum 1 July 31, 2010 07:12
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
