Best way to handle hanging nodes in Fluent for LES? |
November 27, 2013, 12:32 |
Alex
Rep Power: 47 |
Lets say I wanted to use a mesh with a topology like this for LES validations.
block_structure.jpg What would be the best way to handle the interfaces between the mesh regions with different resolutions?
With the focus on LES or later DNS, which approach would be the best in terms of accuracy? I would simply test both methods, but since this is not really part of my project I hope that someone else has some experience to share on this topic. Maybe there are even more possibilities or number 2 and 3 on my list are treated in the same way by Fluent or they will not work the way I expect. Feel free to correct me. Edit: Apparenty, converting hanging node cells to polyhedra is only possible with a 3d-mesh. Last edited by flotus1; November 28, 2013 at 12:48. |
December 15, 2013, 16:16 |
Alex
Rep Power: 47 |
Any thoughts?
December 15, 2013, 16:26 |
As i know there is no possibility to convert hexa to polyhedra in fluent till now: perhaps i make here a mistake.
I think solution number will be the best to follow despite the non conservatism of the turbulent fluctuations through the cells. By the way why not merging all the parts into multibody part and getting conformal mesh for such a geometry or are u posting there only an example. |
December 16, 2013, 03:18 |
#4 | |||
Alex
Rep Power: 47 |
In fact this approach had already been followed by some students under the supervision of one of my colleagues, and the results were not very promising to say the least. Quote:
Another reason is that the filter width of LES subgrid models like Smagorinsky is based on the cubic root of the cell volume, which at least to my understanding is only an appropriate choice if the cell is nearly cubical-shaped. |
December 16, 2013, 03:32 |
As far as i know, method 2 and 3 are not exactly the same (not anymore, at least) but i think the differences are not that big with respect to the main problem here, the fact that the resulting cells are not even closely to be cubical.
I have experience on method 2 for the turbulent channel flow at Re_tau = 590 and a dynamic smagorinsky model; i was unable to get meaningful results with number of grid points comparable to the ones from a structured grid. Actually i used a bounded central scheme, which might have had a strong impact with this specific topology, but i guess the pure central scheme could have created additional problems. To be extremely sure, i would go number 3 (as 2 might have some approximations and is not really developed for LES). Of course, you MUST go 3D, there are no additional MEANINGFUL options for LES. |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
[ANSYS Meshing] ANSYS Fluent mesh export: nodes and edges | Nereus | ANSYS Meshing & Geometry | 1 | December 15, 2011 11:41 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Hexaedra with hanging nodes ? | Alex | FLUENT | 2 | November 1, 2001 18:23 |
