December 10, 2013, 09:47 |
Problem with Injection File
Rep Power: 12 |
I have selected an previously exported injection file, and it seems that Fluent has chosen the default injection scheme for simulation instead of the one I injected. Is there a way to make sure that my injection file is being selected for simulation?
Moreover, the discrete random walk model feature which is required for injections setup under the stochastic tracking tab cannot be enabled. I actually enabled it and the command console stated this feature is enabled. Unfortunately, when I double check again, it is actually not being enabled. How should I solve this problem? Thank you. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
