turbulent viscosity ratio
Old   December 16, 2013, 05:08
Default turbulent viscosity ratio
subhas hunasikatti
subhas.hunasikatti@gmail. is on a distinguished road
Hi friends, I am very new, I am solving the CPU cooling system by using different openings. In this case i have prepaired a 3D model and i have ran in FLUENT, at the time of solving in fluent i got an message like Turbulent viscosity limited to viscosity ratio of 1*10^5. Can any one tell me how to remove or solve the above mentioned message...?
thank you in advance
with regards
subhas
subhas.hunasikatti@gmail. is offline   Reply With Quote
Old   December 16, 2013, 06:05
Persil is on a distinguished road
in the boundary conditions you can raise up the viscosity ratio of your in-/outlet for example
Persil is offline   Reply With Quote
Old   December 16, 2013, 06:15
Albino is on a distinguished road
I got this error after 45s of flow time (with 0.001 timestep) in my simulation today as well. At the same time, my Cl got to like -inf. Before this happened everything looked quite fine.
I assume something else caused the error (bad meshing on my 2D model?). Or is it normal to hit the limit of this ratio?
Im simply modelling (2D) flow over 2 cylinders (where one can move).
Albino is offline   Reply With Quote
Turbulent Viscosity limited to viscosity ratio problem in pneumatic conveying shubham208011 FLUENT 1 June 26, 2013 10:37
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 11:04
Turbulent viscosity ratio limited to 1.10^5 in boundary layer ingestion loicflouriot FLUENT 0 May 27, 2012 07:31
turbulent viscosity limited to viscosity ratio of 1.000000e+05 syler3321 FLUENT 4 March 16, 2012 16:00
turbulent viscosity ratio James Willie FLUENT 1 June 21, 2005 03:35
