Shock tube simulation
Old   May 11, 2008, 16:35
Default Shock tube simulation
harish
I am trying to run a shock tube simulation on a tube with a 5m driver section; and 10m driven section (with air on both sections). I am running 2D simulations but with only one cell in the y-direction (normal to the shock direction) and symmetric boundary conditions on the upper and lower walls. Both end walls are set to the wall-boundary condition.
The configuration is shown below:
---------*---------------------------- | Driver | Driven | ---------*----------------------------
I am using the following configuration for the solver:
coupled, unsteady implicit solver with energy enabled; 2nd order discretization; node based gradient method; density goes as ideal gas; cp etc remain constant; Courant# = 0.5
The problems are:
1. The shock wave is too shallow (over several grid points)
2. The shock wave moves too fast compared to 1-D calculations (almost twice as fast as expected)
Clearly, I am messing things up pretty bad. Any help/pointers/sample jou files/example problems/example solutions would be much appreciated.
(This is not for any class -- I am trying to figure out the effect of putting a side-chamber in a shock tube)
Old   May 11, 2008, 16:46
Default Re: Shock tube simulation
harish
sorry, the picture did not come out right
|***driver*********|******driven*******|
Old   July 8, 2009, 13:31
Nishant Kumar
Nishu is on a distinguished road
Hi Harish,
Can you please send me the 1D code for shock tube problem at babuu.nishu@gmail.com? I need it for my research.
Thanks a lot
Nishant
Nishu is offline   Reply With Quote
Old   July 29, 2009, 13:52
tramber is on a distinguished road
Hi Harish,
I did such a validation a few years ago with Fluent 6.2 or 6.3
I obtained similar results comparing the coupled-implicit (today refered as density based implicit) to the coupled-explicit (previously called Rampant and today refered as density based explicit).
Both matched the exact solution pretty good.
Note that I more than one cell in the y direction.
I can provide you with the msh and jou if you still need it.
tramber is offline   Reply With Quote
Old   August 3, 2012, 22:04
Ali Jafarizade
jafarizade is on a distinguished road
hi tramber
i do really need your mesh and journal files of the shock tube.
is it possible for you to mail me what you have such as mesh file and journal files and etc?
i will be a very good help for me and i do appreciate your help.
my email is jafarizade@yahoo.com
thanks in advance!
jafarizade is offline   Reply With Quote
Old   January 25, 2014, 02:20
Charisma Joseph
charisma is on a distinguished road
hey tramber
can you please mail me those files too? the msh file and journal files.
my email is charismaannjoseph@gmail.com
thank you.
charisma is offline   Reply With Quote
shock tube!!! showwa FLUENT 12 May 20, 2012 19:14
shock tube Shuo Main CFD Forum 5 August 16, 2007 23:54
shock tube tal FLUENT 0 June 23, 2007 21:25
Shock Tube Pooria Sattari Main CFD Forum 5 June 14, 2005 00:55
shock tube anin Main CFD Forum 1 August 4, 2001 22:58
