February 11, 2014, 04:58 |
Playback animation mesh
Anna-Sofia
When using a dynamic mesh, is it possible to record the transient changes in the mesh?
Is it possible to save a picture of the mesh each time FLUENT remeshes? |
February 12, 2014, 09:00 |
Francisco
Rep Power: 15 |
Hi Anna Sofia,
You can define an animation at Calculation Activities/Solution Animation- Create/edit You can choose how often (iterations or timesteps) you want to save a picture, and you can select the picture format, the camera viewpoint, the variable, etc. at Define. You can animate all the frames later on in Graphics and Animations/Solution Animation Playback. Hope this helps |
February 13, 2014, 09:15 |
Rick
Rep Power: 26 |
Or if you want to use third party softwares for post-processing, as tecplot for example, you have to save both cas files (in which you save each step of "the dynamic mesh") and dat files (in which you save solutions).
Then you will import cas and dat files and you can create mesh animation; without cas files your mesh will not move. Daniele |
animation, dynamic mesh, playback |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
