February 1, 2012, 07:55 |
Natural Convection heat transfer problem
sree
Rep Power: 14 |
Hello everyone.
I have one problem related to heat transfer natural convection. Problem statement: A rectangular box containing bus bars,due to flow of current heat is generated.The heat is distributed by mode of convection(natural Convection).Intially there are openings below and above of the rectangular box which acts as a inlet and outlet for airflow.I simualted it in fluent and i got the satisfactory result.Now,i have to simulate the similar one with NO INLET and OUTLET that is the rectangular box to be fully enlcosed.I have to find the bus bar temperatures now with the air which is intially have. can any one help me to give the boundary conditions . regards srinivasa |
February 1, 2012, 08:39 |
ANTONY AROUL RAJ V
Rep Power: 14 |
You can take the box domain as fluid and the outer wall as insulated(heat flux zero). The heat released by the heater surface can be simulared by giving the heat flux boundary condition. Heat provided by the heater can be converted to heat flux by dividing the heat by the surface area of the heater.
Enable the energy. Natural convection can be simulated by enabling the gravity in the operating condition panel and also giving the gravity value correctly in the gravitaational accelaration form.(careful about the direction of g). |
February 1, 2012, 08:52 |
sree
Rep Power: 14 |
thank u..
i will try for it |
February 1, 2012, 09:11 |
sree
Rep Power: 14 |
Hi Antony..
were i have to define the air temperature. |
February 1, 2012, 09:42 |
ANTONY AROUL RAJ V
Rep Power: 14 |
Give the initial condition if it is transient analysis and intial solution if it is steady state analysis in the iterate panel (may be 30 deg cent) .
February 2, 2012, 00:47 |
kat
Rep Power: 14 |
hey whenever i give heat flux to the source and source shadow.its showing divergence detected in AMG Solver.pliz help.One more thing since its a electric current heat dissipation should we have to give heat generation??
February 2, 2012, 02:16 |
sree
Rep Power: 14 |
Hi antony.
i have given air temp as 24 at initalisation. as my problem is steady state.. but it solution is not converging.shall i use any relaxation factors. |
February 2, 2012, 02:57 |
kat
Rep Power: 14 |
are you working for a switchgear? internal arc modelling??
February 2, 2012, 19:35 |
#9 |
ANTONY AROUL RAJ V
Rep Power: 14 |
Dear mr Srinivasa
Tell me whether your monitor graph residuals are decreasing or increasing with iterations. If the slope of the decrease is very less, you can go for relaxation. Also you can use boussniques model for fluid density (instead of constant) to model the change in density with temperature of the fluid in the fluid material property panel. |
February 2, 2012, 19:46 |
#10 |
ANTONY AROUL RAJ V
Rep Power: 14 |
Dear Mr Karthik
If you are modelling the heater as surface(face) You can give surface heat flux bc. If you are modelling it as a solid volume, you can give it as heat generation per unit volume. If it is a volume there should be mesh connectivity between heater and surrounding fluid. If divergence is there in temperature it may be due to wrong bc, initial condition or check the 'solve from' in the iterate panel. You can change the solve from location. You can also use the boussnisques model for density(details in previous message) |
February 3, 2012, 15:09 |
#11 |
guru
Rep Power: 14 |
Dear Friends,
I am too working on the same problem. Please give me any details u have regarding the problem because i'm too stuck with the solution. is it necessary to initialize the solution from a specific zone. please reply as soon as possible.. my email id is gaurav_1guru@rediff.com |
February 5, 2012, 22:31 |
#12 |
kat
Rep Power: 14 |
exactly same problem im facing now
February 6, 2012, 03:05 |
#13 |
sree
Rep Power: 14 |
Dear Antony..
My Residual graphs are osciallting.. i am using the Boussinesq model only. |
February 6, 2012, 09:27 |
#14 |
ANTONY AROUL RAJ V
Rep Power: 14 |
Dear Mr Srinivasa
Are you doing transient analysis. Can you upload the picture of residual graph. I will try giving suggestions. |
February 6, 2012, 09:29 |
#15 |
ANTONY AROUL RAJ V
Rep Power: 14 |
Dear Mr Gaurav
Please eloborate about your problem for giving suggestions. |
February 6, 2012, 12:28 |
#16 |
guru
Rep Power: 14 |
http://www.cfd-online.com/Forums/flu...ng-fluent.html
please go through this link it has description of geometry and the problem.. |
February 6, 2012, 22:24 |
#17 |
kat
Rep Power: 14 |
from which zone should we do solution initialisation??
February 7, 2012, 11:00 |
#18 |
guru
Rep Power: 14 |
I have attached the residuals plot for steady analysis...
can u suggest me how to do transient analysis.. |
February 8, 2012, 03:50 |
#19 |
kat
Rep Power: 14 |
which solver should i select for transient condition natural convection involving high temperature and pressure variation...shock waves invovled adaibatic change in an enclosure
February 17, 2012, 10:43 |
#20 |
guru
Rep Power: 14 |
please reply soon
ntrl conv in enclosure |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Multiregion Heat Transfer + natural convection (water) with chtMultiRegionFoam | fattychickenrun | OpenFOAM | 5 | October 31, 2011 16:53 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
Natural Convection with heat generation | krishnachandranr | Main CFD Forum | 0 | July 28, 2009 04:22 |
Heat transfer problem | Brian | CFX | 0 | September 13, 2004 01:19 |
