March 19, 2014, 18:41 |
Slow Transient Solution
Rep Power: 12 |
I am doing a 2D transient simulation of an aerofoil passing a cylinder to simulate a wind turbine blade passing a tower using a sliding mesh. At the moment my solution is taking quite a while (over 24 hours). A problem I am finding is that I have set the maximum iterations per time-step to be 800 and it seems to use up all 800 for nearly every time-step. I was under the impression that after the solution settles down it should only take ~50 iterations. I have set the time step to be the time taken for the mesh to slide the length of the smallest element. For example I am plotting Cl vs time throughout the solution and I understand that the solution needs to settle (possibly due to limiting it to 800 iterations/time step) but I would assume that after a while. Any help or advice would be appreciated, I have attached some images of the mesh if that helps. |
March 21, 2014, 03:19 |
Flavio
Rep Power: 15 |
Hello scoobysimon,
I'm not expert in airfoil (I've never simulated one), but I'd say that usually in transient simulation the number-it/time-step is less important than the time-step value: I never used such a large number of it/time-step (max 20-30). I suggest trying 20 it/time-step and reducing the time-step checking your time-discretization. Regards
Bionico |
slow, solution, transient analysis |
Seeing results at different time steps of a transient solution. | juZby | FLUENT | 4 | January 20, 2013 23:17 |
Transient Solution looks like Steady State | ljwnow | FLUENT | 0 | March 26, 2012 01:54 |
transient solution | faw | FLUENT | 2 | March 12, 2012 11:25 |
Best practice for transient simulations? | siw | CFX | 5 | October 30, 2010 05:45 |
Problem with transient solution of flow past a row of cylinders | jostanek | Main CFD Forum | 0 | January 6, 2010 12:16 |
