Moving mesh and thermodynamic issues...
Old   April 4, 2014, 02:32
Cool Moving mesh and thermodynamic issues...
Lukasz
loook is on a distinguished road
I am working on simulations with moving meshes. I have noticed several strange things using moving mesh:
I did simple simulation of a piston which first compress the gas and then moving backward letting gas to expand. There is no heat flux, just motion of a mesh. When I monitor the pressure and total volume I do get positive work!!? How is it possible...?
The other thing is heat flux through moving boundary. I have made the "total heat flux report" on each of boundaries and I have noticed relatively large heat flux through my moving boundary (even so it is set to adiabatic) why is that?
I did it via Report/Fluxes/TotalHeatTransferRate - does any body know how to monitor this particular flux and write it to file? ( i tried surface integrals... averaging and non of those gives me this strange flux)
I will be appreciated for help with those problems...
loook is offline   Reply With Quote
Old   April 4, 2014, 04:37
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi loook,
have you tried disabling Energy from Equation menu?
Regards
Bionico
Bionico is offline   Reply With Quote
Old   April 4, 2014, 04:58
Lukasz
no I did not, because I need to solve the energy. This is a problem I came up with during other simulation. In this other simulation i have two heat exchangers cold one and hot one. I got there work from PdV diagram and work from heat fluxes from heat exchangers (Qh-Qc). I found that they are different by 20% !. So it is kind of strange that I get different amount of work depending on how do I calculate it.
This is why I have tuned off the heat exchangers (in order to get adiabatic case) and got this strange results....
compression, heat flux, moving mesh, thermodynamics
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
