April 7, 2014, 10:30 |
Error-read mesh
Simone Di Giorgio
Rep Power: 12 |
hi,
fluent report this error when I tried to read the mesh. Reading "C:\Users\Di Giorgio Simone\Documents\fluent\s1223_nonstrutturata\fluen t3D.msh"... Clearing partially read grid. 17289 nodes. 67261 tetrahedral cells, zone 10. 115884 triangular interior faces, zone 11. 5331 triangular wall faces, zone 12. Building... mesh Cell Centroid is xc 27.940647 yc -2.880479 zc -0.730874 WARNING: cell 0 of thread 10 has NULL face pointer 3. Clearing partially read grid. Error: Build Grid: Aborted due to critical error. Error: Build Grid: Aborted due to critical error. Error Object: #f |
April 7, 2014, 12:15 |
Rick
Rep Power: 26 |
Hi!
it seems you have to go back to preprocessing to remesh your volume(s). |
April 8, 2014, 05:05 |
Sanket Dange
Rep Power: 12 |
Hi Simone,
As said by Daniele, you need to go back in you pre processing software. There seems to be some problem in your mesh. Just check your mesh, solve the problem (you might need to remesh) and then bring your mesh back in Fluent. |
April 8, 2014, 17:57 |
Simone Di Giorgio
Rep Power: 12 |
I solved it by deleting the volume meshs.
i'm trying to create a mesh for a 2D geometry, but i can't with the command for the surface mesh. |
June 1, 2014, 04:46 |
tmeysam92
Rep Power: 14 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre | powpow | CFX | 3 | December 20, 2012 09:14 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
