casting solidification
Old   September 11, 2015, 08:51
Default casting solidification
giuseppe lombardo
peppelmb is on a distinguished road
Hello everybody, I'm quite new at Ansys and I'm trying to do a 3D solidification simulation using Fluent. In particular, I'm working on an aluminum casting made from a sand casting process. I decided to use a specimen, as a representative part of my process, which has been reduced in geometry to its initial gauge length. As a result I have, as can be seen from the screenshot below, a cylindrical aluminum piece surrounded by a cast iron chill and the sand mould. What I want to figure out is how to do the simulation, starting by put the boundary conditions, passing through the mesh setting and finishing up with the computational setup.
Does any of you guys have a 'standard' procedure for this kind of work? Thanks in advance.
peppelmb is offline   Reply With Quote
Continuous casting simulation problem luke.christ FLUENT 6 November 24, 2020 07:14
Flow and solidification in continuous casting lynn Fluent Multiphase 8 April 2, 2019 01:24
Modelling Solidification in Continuous Casting raagh77 FLUENT 0 January 30, 2014 00:03
Casting Solidification Model Behdad.Nayebi FLOW-3D 3 January 29, 2013 08:05
About the solidification? H.P.LIU Phoenics 1 December 1, 2010 09:49
