why the cavitation incepts in the area of high pressure ?
Old   April 23, 2014, 10:11
Question why the cavitation incepts in the area of high pressure ?
cuocuozhuo
cuocuozhou is on a distinguished road
I use the software FLUENT 14.5 to simulate this case.
I use liquid-vapor two phases method:I choose the k-e model, two phases mixture model and s-e-a model.
Boundary conditions are as followsressure inlet,total pressure is 101325 Pa; volume fraction of vapor is 0 at the inlet.; Pressure outlet, 0 Pa.
The result shows that the pressure in upstream area is higher than 8.8e +04. I think there shouldn't be cavitation. But the result shows that the vapor volume fraction is higher than 6.5e-03. I don't think it is reasonable.
I tried other models like schnerr-sauer model and zwart-gerber-belamri model.The results are same as this.
I think maybe you can help me. Thank you.
cuocuozhou is offline   Reply With Quote
cavitation, two-phases method, vapor
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Tutorial problem: "rhopSonicFoam - shockTube" with high pressure shangzung OpenFOAM 0 November 1, 2009 13:07
high pressure simulation mahi FLUENT 0 November 7, 2008 01:30
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
