Meshing fluid through a packed bed of particles
Old   April 25, 2014, 08:45
Angry Meshing fluid through a packed bed of particles
Oliver O'Connell
oocon is on a distinguished road
The geometry is a random pack of 'pebbles' in a cylinder as shown in the image below:
https://www.dropbox.com/s/8q4pvx5fqstp0xr/pebbles.PNG (don't know why the IMG tag isn't working?)
I imported this into Workbench and did a Boolean cut to remove the geometry of the pebbles from the cylinder:
https://www.dropbox.com/s/bnbod6019vpup32/pebbles2.PNG
Within the meshing program I set the top and the bottom to inlet and outlet respectively and the outside of the cylinder and all its inner faces to walls - but I can't get it to mesh! I must be doing something wrong, because it either hangs or just gives me the error:
"The following surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology."
I'm quite new to this so I am not quite sure how to fix this problem.
oocon is offline   Reply With Quote
[ANSYS Meshing] Solid inside Fluid - Multizone meshing supercolli ANSYS Meshing & Geometry 2 July 9, 2014 13:20
ANSYS CFX meshing bed of particles Tim Donohue CFX 1 November 11, 2007 05:44
Packed Bed Prakash Verma FLUENT 1 October 27, 2004 06:47
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Particles in slow dense fluid newbie Main CFD Forum 6 December 6, 2001 09:43
