May 2, 2014, 03:30 |
2-D double wedge in Hypersonic flow
Subhasree
Rep Power: 12 |
I am modeling a 2-D wedge in hyper-sonic flow having the following free-stream conditions: Mach no-9.59 Temperature-185.6k Pressure-36.5Pa I have used the following setup in fluent post: Desity based fluid-Ideal gas standard initialization from farfield I tried running the 1000 iterations initially...in which the continuity and energy equations are hardly changing while the x velocity is having a negative slope(convergence), the y velocity is having a positive slope(divergence)..i having tried reducing the cfl value...it is showing the same trend as I increase the number of Iteration...plz sugest how should I proceed |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Hypersonic flow over double wedge | marilyn | FLUENT | 7 | April 20, 2013 14:26 |
Hypersonic flow over a wedge | Ravenn | FLUENT | 6 | March 7, 2013 07:12 |
Errorneous velocity near walls while using wedge type BC for axisymmetric flow | diwakaranant | OpenFOAM Running, Solving & CFD | 0 | February 9, 2013 00:41 |
Hypersonic flow scramjet | ishaninair | OpenFOAM Running, Solving & CFD | 0 | March 10, 2011 07:45 |
