May 19, 2014, 05:46 |
help....ansys fluent 14.5.....no results...
mariana
Rep Power: 12 |
hello,
i am doing my thesis in Ansys flunet 14.5. i made mesh and now i am at the step 3, set up-solution. my case is sub-marine in the sea. i am doing that like i have open channel input data are based pressure, time steady, velocity formulation absolute, multiphase-volume of fluid, vuscous-realizable k-e, materials--> water and air, 2 phases, input-mass flow rate--> mixture, but i chose before in air and water the numbers that i wanted, outlet-pressure outlet, solution methods-scheme-coupled, solution intilazaration-open channel initialization method-->flat and run calculation. the errors that i have are: Divergence detected - temporarily relaxing and trying again... Divergence detected in AMG solver: pressure coupled Primitive Error at Node 1: floating point exception Error: floating point exception Error Object: #f as you understand i don't know where is the problem. Can you help me??? |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Problem with Dynamic Mesh in Ansys Fluent 14.5 | alireza_b | FLUENT | 2 | May 10, 2013 08:20 |
Results are different for Ansys Fluent 14.0 and Fluent 6.3 | syavash | Fluent UDF and Scheme Programming | 1 | February 17, 2013 01:09 |
Visualize results from ANSYS Ls-Dyna, | mechanicaldesign | ANSYS | 0 | January 21, 2013 23:37 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
