May 29, 2014, 03:06 |
Unstedy fluid flow in Porous media
Ebrahim
Rep Power: 12 |
In unsteady 2D modelling water flow in a rectangular porous media (10 meter length and 5 meters wide) with permeability of 1e-10 m/s and porosity 0.3, with 50000 pascal pressure for water inlet (left side) and 0 pascal for outlet (right side), I have chosen 1000 seconds for fluid flow (time step size 1, number of time step 1000), but the results showed that the water have passed through the medium about 5 meters (more than half of the medium) which does not make sense!!!
I was wondering to know if some one could tell me what is wrong whit my modelling? |
May 29, 2014, 11:04 |
François Grégoire
Rep Power: 17 |
May 29, 2014, 13:13 |
Ebrahim
Rep Power: 12 |
Hi
Thank you for your comment: yes I mean 1E-10 m² which is 1/permeability (m/s) and the permeability magnitude is 1e10 m/s. would you please tell me what is the difference in the results? |
May 29, 2014, 14:00 |
François Grégoire
Rep Power: 17 |
May 29, 2014, 15:08 |
Ebrahim
Rep Power: 12 |
For modeling of porous media fluent uses viscous resistant in terms of 1/m² which is equal to 1/α.
And α is permeability of the medium (m/s), so if you want to model a porous media with permeability of 1e-10 m/s you should insert the viscous resistant of 1e10 (1/1e-10). Would you please tell me if I am right? |
May 29, 2014, 15:25 |
François Grégoire
Rep Power: 17 |
You can't abracadabra m² units from m/s units. Googling for 10 seconds makes me think you're confusing hydraulic conductivity (expressed in m/s) with permeability (expressed in m²). In Fluent User's Guide, permeability is in m² and viscous resistance is in 1/m².
In my first post I did a quick estimation with the help of Darcy's law and I mysteriously got the same result than your simulation, but 1 order of magnitude off. That made me think that maybe one of your numbers is wrong by 1 order. |
May 30, 2014, 07:08 |
Ebrahim
Rep Power: 12 |
The isotropic permeability coefficient, k (e.g., m2/(Pa/sec) in SI units), is the coefficient of the pressure term in Darcy’s law and is related to the hydraulic conductivity, kh (e.g., m/s), by the expression
kh = kgρf where g is the gravitational acceleration. The intrinsic permeability, κ (e.g., in m2), is related to k and kh, as follows: κ = μ kh/gρf = μk where μ is the dynamic viscosity. It seems that FLUENT uses the intrinsic permeability. And if the if the isotropic permeability of medium is 1e-10, to have Darcy velocity of 0.5 m/s in the mentioned modelling , the value of 1e13 should be inserted as viscous resistance (Dynamic viscosity of water is 0.001 kg/(m-sec)). Am I right? Best regards |
May 30, 2014, 12:19 |
#8 | |
François Grégoire
Rep Power: 17 |
: permeability (m²) If permeability is 1E-10, viscous resistance is 1E10! Look at the attached excerpt from User's Guide 15.0, the viscosity is not included in the viscous resistance. |
May 31, 2014, 04:18 |
#9 |
Ebrahim
Rep Power: 12 |
Now we have returned to the beginning
Inserting the viscous resistance 1e10 (1/α) where α = 1e-10 m2 for my model, results in the water transport about 5 meters!!! What else do you think that might be its reason? |
Flow parallel to porous media | HannesVV | CFX | 1 | June 29, 2013 07:28 |
Flow in porous media + phase change | styleworker | FLOW-3D | 1 | June 27, 2012 14:51 |
fluid flowing through the porous media | fairuz_hafizan | Main CFD Forum | 3 | March 1, 2011 15:11 |
Testing the integrity of POROUS media and por jump | Azman | FLUENT | 0 | July 31, 2006 11:11 |
porous media flow | Siraj | Siemens | 4 | February 24, 2006 22:24 |
