CFD of Vertical Axis Wind Turbine
Old   June 1, 2014, 21:47
Default CFD of Vertical Axis Wind Turbine
shashank mishra
shashankmechguy is on a distinguished road
I am a beginner in using Fluent.
My objective is to perform cfd analysis of VAWT.
While trying to create interface , i am getting this error "The mesh file exporter does not support overlapping geometry in named selections. Please resolve the issue and try again. You can use the option “Show Geometry in Overlapping Named Selections” (when you right click on the Mesh branch of the tree) to help diagnose the problem."
I have attached geometry file.
Also it is possible to give inlet air velocity and calculate what will be the rpm of wind turbine.
Thanks in advance.
https://drive.google.com/#folders/0B...3BscE1SamIwQkU
shashankmechguy is offline   Reply With Quote
fluent 15.0
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 06:13
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 17:18
Vertical Axis Wind Turbine PiotrekL1 Autodesk Simulation CFD 3 May 29, 2013 14:20
need wind turbine data for cfd validation Reggio Main CFD Forum 0 September 9, 2012 11:30
Reversed flow in Vertical axis wind turbine Anonymized_JL1 FLUENT 0 April 16, 2010 23:20
