fsi- not enough memory
Old   June 28, 2014, 06:25
Default fsi- not enough memory
mb1368 is on a distinguished road
Hi every one
I try to simulate two way fsi by using fluent+transient structural+system coupling, but I face to this error:
set-residual-history-size: not enough memory
Do anyone Know how to solve this problem? I try to coarse mesh or lessen time step or change to first order accurate and local parallel, but they don't work.
my systems characteristics are: corei5, 4GB memory
mb1368 is offline   Reply With Quote
Old   June 28, 2014, 13:41
Rohit Sharma
Rohitah is on a distinguished road
Hi
The problem lies in your pc. It is unable to process your result because of its processor and its RAM memory. You need to try higher the both of it.
Rohitah is offline   Reply With Quote
Old   June 28, 2014, 15:41
Hi Rohitah, thanks for your reply. but when I try to run fluent alone, it works without error.is this problem just for fsi?
Old   June 29, 2014, 02:01
Rohit Sharma
Not exactly. It depends on your case. If it is heavy, it may show the same.
Old   August 11, 2017, 05:29
rezaeimahdi's Avatar
mahdi
rezaeimahdi is on a distinguished road
Originally Posted by mb1368 View Post
Hi every one
Maybe it's a little old, but did you find any solution for that?
I'm working on FSI simulation and the same problem just for coupling and no problem when I run a case just with fluent in parallel.
Thanks
rezaeimahdi is offline   Reply With Quote
Old   August 11, 2017, 10:32
Cees Haringa
CeesH is on a distinguished road
Did you check your task manager to see how your RAM load is? Most likely, it's simply a matter of insufficient memory in your computer, which means either reducing the number of grid cells until you do manage to load the whole case, or buying a few extra memory banks.
CeesH is offline   Reply With Quote
Old   August 11, 2017, 12:14
mahdi
Dear Cees,
Thank you for your reply.
my case doesn't have too many cells ( ~150,000 in fluid domain and ~60,000 in solid part). I have run this case in Ansys 16.0 installed in windows 7 without any problem. But the problem started when I run the same case in windows 10. Should be some thing wrong relative to operation system I suppose.
I am trying to understand why it's happened, however, I will appreciate let me know if you have any Idea in this matter.
Thanks
Old   August 12, 2017, 06:27
mahdi
In my case, the problem solved after updating computer drivers with DriverPack Solution.
https://drp.su/en/foradmin
Solver error message - memory usage Jared1986 CFX 12 December 2, 2014 06:28
Lenovo C30 memory configuration and discussions with Lenovo matthewe Hardware 3 October 17, 2013 11:23
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
INSUFFICIENT MEMORY ALLOCATED Error for FSI Cuong CFX 2 November 6, 2006 20:48
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 18:50
