Pipe flow heat transfer
Like Tree3Likes
  • 1 Post By macfly
  • 2 Post By flotus1
Old   July 31, 2013, 10:37
Question Pipe flow heat transfer
Quentin
feedq is on a distinguished road
Hello all,
I am attempting to model a simplified model of a copper pipe transfering heated water through an environment. My goal is to determine the heat loss of the pipe with different fluid and environment temperatures.
My conditions are as follows:
323K fluid temperature, 1.5m/s fluid velocity, water-liquid
15mm pipe radius (quartered cross section to reduce complexity), 2mm thickness, 2m pipe length, copper
293K environment temperature
At first I modeled the pipe within an enclosure, created a coupled wall between the pipe wall and enclosure and turned on the energy equation. K-Epsilon was used for the viscous flow model. Radiation was also enabled.
The results I got were very off. The heat loss along the length of pipe is very eratic (as can be seen from my XY plot of temperature along the pipe's length).
Any help that anyone could give would be greatly appreciated.
Thanks in advance.
Regards,
Q
feedq is offline   Reply With Quote
Old   July 31, 2013, 10:40
Quentin
Forgot to post the XY plot
As can be seen there is very odd temperature differences along the length. I also attached a picture of the temperature contour plot of the enclosure and pipe which shows no heat escaping into the enclosure
Old   July 31, 2013, 14:13
Quentin
I appreciate I haven't explained the problem very clearly. If anyone requires further information please say.
Any help would be greatly appreciated
Old   July 31, 2013, 15:04
François Grégoire
macfly is on a distinguished road
You can just model the pipe without the enclosure, unless you are interested in the flow features in the enclosure? You could just impose a convection boundary condition a the pipe surface, no enclosure. You have to estimate a heat transfer coefficient at the surface of the pipe, see some heat transfer book for that.
feedq likes this.
macfly is offline   Reply With Quote
Old   July 31, 2013, 15:12
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
s..t in, s..t out
The mesh you use violates the basic rules for finite volume meshes.
In addition to being way too coarse in the surrounding region near the pipe, there are no prism layers for the fluid outside the pipe.
It is not clearly visible how many cells represent the radial direction inside the pipe. but it looks like 1 or two, again without prism layers.
rayan24 and feedq like this.
flotus1 is offline   Reply With Quote
Old   July 31, 2013, 15:25
rayan
rayan24 is on a distinguished road
I confirm that have been said by Alex, the mesh is not clean.. I recall that the finite volume method is conservative therefore made sure that the mesh is clean
rayan24 is offline   Reply With Quote
Old   August 1, 2013, 07:47
Quentin
Thanks for the suggestions guys. I removed the enclosure because as stated before I am only interested in the pipe's fluid temperature drop.
Hope it sorts it out! I'll post results soon
Old   August 1, 2013, 09:24
Quentin
Sh*t in = sh*t out indeed!
Simplifying the model has sorted it out. The results are far more realistic.
Thank you all for your help
Old   August 1, 2013, 09:26
Quentin
Forgot to clarify..
I simply removed the enclosure, changed the wall thermal settings to convection, used 13.1w/m^2.k for heat transfer coefficient (water-copper-air) and 293K free stream temp. Fixed.
Old   November 26, 2014, 04:37
Default heat transfer in a pipe
aliahmadi
aliahmadi is on a distinguished road
hi friends
i am a new user of openfoam and i need to simulate the heat transfer of water in a pipe whit the air out side.
can i use bouyantpimplefoam solver.
or i should use chtmultiregionfoam solver.
i create the geometry with wedge type boundry and toposet rule.
please help me
aliahmadi is offline   Reply With Quote
Old   November 26, 2014, 08:23
François Grégoire
Originally Posted by aliahmadi View Post
hi friends
please help me
Please ask your question on the OpenFOAM forum: http://www.cfd-online.com/Forums/openfoam-solving/
[ANSYS Meshing] heat transfer through a pipe cfdjunkie ANSYS Meshing & Geometry 3 September 18, 2012 21:53
Conjugate heat transfer in reacting flow ali_1364reza OpenFOAM 1 May 30, 2012 14:15
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
