July 6, 2014, 15:02 |
Problem with boundary conditions
Hello, I am trying to analyze the flow through a catalyst. I do the mesh the interior volume separating the inlet pipe, the catalyst volume, and the outlet pipe.
The problem is when I pass it to Fluent, since in "Boundary Conditions", the contact surfaces are considered as 'wall', instead of 'interior'. When ANSYS does the mesh, it creates two contact surfaces, but I supose it isn't enough. How can I solve this? Thank you very much! |
July 6, 2014, 17:04 |
A-A Azarafza
Rep Power: 14 |
OK pal,
It seems that there are more than one surface in the mentioned place (it may two surfaces overlap on each other), so you can't distinct them easily. It's a very common mistake during model design which comes from wrong usage of split tool. I had the same problem many times and I resolved it with making some effort. I hope it helps
Regard yours |
July 7, 2014, 05:11 |
Thank you very much for your reply.
I have found the problem. I must enable 'Assembly Meshing' in the 'Mesh Details'. The mesh hadn't continuity, so Fluent considered them as wall, that is to say, different objects. Problem solved!! Kind regards!! |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
Problem with Periodic Boundary Conditions Help!!! | otsigun | FLUENT | 0 | July 11, 2013 03:20 |
Boundary Conditions problem | o_mars_2010 | Main CFD Forum | 2 | July 8, 2013 02:10 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Problem with Boundary conditions | Mahiboobswamulu | Main CFD Forum | 10 | August 26, 2003 13:24 |
