Urg: Particle tracks discrete phase summary sample
Old   July 18, 2007, 15:41
Default Urg: Particle tracks discrete phase summary sample
fivep
Hi all,
I am monitoring the particles that are trapped on surface A, and exit through outlet B and outlet C.
1. For some reasons, discrete phase summary cannot be shown (I can only get info from report>discrete phase>sample or histogram). Do you know how to retrieve the summary?
2. When I use report>discrete phase>sample to calculate numbers of particles tracked/escaped/trapped/aborted/etc. from each boundary (I didn't create surface>plane), it seems that the values are all the same no matter which boundary I pick. Do you know why?? And so, how can I calculate the numbers of particles escaped/trapped/etc from each surface??
Many Thankssss!!!
Old   July 19, 2007, 03:01
Default Re: Urg: Particle tracks discrete phase summary sa
ritmat
one of my problem was as well that if i created a surface and wanted to watch the particules at this surface , but it was showing all particules on the plane corresponding to that surface. So means on your whole geometry belong to that plane not limited... maybe it can be your problem as well. To overcome that i used the file i got in excel and remove values i didnt want. But if you succeed to make it work better i will be glad to hear that. cu
Old   July 7, 2014, 06:39
SJSW is on a distinguished road
I have the same problem in sampling particle number and diameter walking through the outlet in a transient simulation using ANSYS 14 Fluent. The major part is that the function "appending file" can't be activated with the box checked and the button "start " clicked. Could anyone be kind to help solve this? That would be a great help.
SJSW is offline   Reply With Quote
Old   July 7, 2014, 07:16
Another problem coming...
The output file is named XXX.dpm,
and it can be opened with Notpad or Excel.
The content header is as follows:
x y z u v w diameter t mass-flow mass frequency time name
x, y and z is the positions.
u, v and w is the velocity.
I don't know the meanings of "t," "mass-flow," "mass," "frequency," "time," and "name."
Could anyone help?
Old   July 21, 2014, 00:01
Results→Reports→Discrete Phase→Sample→Set up...→Start→Stop→Start
Run Calculation→Calculate
x y z u v w diameter t parcel-mass mass n-in-parcel time name
diameter ?? of particle or parcel??
t is temperature
parcel-mass is the total mass of particles in a parcel
time ??
name ?? I don't know the meaning or how they are assigned...
Anyone help please?
Old   July 21, 2014, 04:48
diameter is for "particle." I calculated the density and got this conclusion.
The .dpm file recorded the particle properties.
The numbers of tracked, escaped, aboted and so on in TUI window are for "parcel."
However, the meaning of "time" is not understood yet.
Anyone help please? qq
Eularian vs Discrete Phase Particle Tracking AndyR Main CFD Forum 0 November 10, 2010 09:30
Discrete Phase Summary disabled - trying to find total mass! shankara.2 FLUENT 1 October 12, 2009 02:41
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DPM Particle tracks summary text input Rajesh Gutti FLUENT 1 October 17, 2008 02:29
Discrete Phase Model - Particle Tracking johnnyb FLUENT 0 March 17, 2004 09:36
