Problem with non-premixed model
Old   August 27, 2012, 23:12
Default Problem with non-premixed model
wei jet
weijet is on a distinguished road
I am using pdf-mixture (non-premixed model, equilibrium, non-adiabatic) with dynamic mesh to simulate in-cylinder pressure of a diesel engine. The predicted in-cylinder temperature would experience sudden increase until the maximum limit of the PDF table (the spike occurs at 900K) but the predicted in-cylinder pressure would have a sudden decrease. This makes no sense at all as the temperature and pressure should be proportional to each other in a closed system. As for the detail of the pdf table generation, C12H23 is simply set as the fuel and O2,N2 are set as the oxidiser.
weijet is offline   Reply With Quote
Old   August 7, 2014, 08:34
Dhanashree
dpw_1411 is on a distinguished road
did you get a solution for ur problem?
dpw_1411 is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Turbulence model for mixing problem nileshjrane OpenFOAM Running, Solving & CFD 1 September 7, 2010 17:48
premixed flame modeling problem peiyong wang CFX 1 July 18, 2008 12:02
Non premixed model - combustion validation problem David FLUENT 2 October 24, 2003 10:06
Two phase Eulerian Model Problem senthil FLUENT 5 May 21, 2003 02:55
