DES Relative Length Scale in Fluent never positive, why?
Old   October 15, 2014, 13:14
Default DES Relative Length Scale in Fluent never positive, why?
ChezLeon is on a distinguished road
We are trying to do DES simulations around a bluff-body. We choose k-eps realizable as the RANS model in DES and we have appropriate mesh resolution near walls for advanced wall treatment.
We want to check which parts of the flow are handled with LES. I attached a sample contour of Relative Length Scale (DES) on a horizontal cut-plane.
The whole domain does not contain any elements with positive values of relative length scale. You see on the contour that there are very small negative values, but no positive values.
What might be the meaning of this? Should we not use relative length scale to distinguish between RANS and DES regions? I couldn't imagine that the whole domain is in RANS mode, as we have quite different results with much more visible eddies in DES simulations than in pure RANS simulations. So I assume there must be a LES region.
Thank you very much in advance for your reply. We are in a critical situation.
Additional Note:
Fluent Documentation:
Relative Length Scale (DES) (in the Turbulence... category) is defined by
Ls = Ls_rans - Ls_les (30.4-24)
where Ls_rans is an RANS-based length scale, and Ls_les is an LES-based length scale. All of the cells inside the domain in which Ls > 0 belong to the LES region, and all of the cells inside the domain in which Ls < 0 belong to the RANS region.
ChezLeon is offline   Reply With Quote
Old   October 17, 2014, 07:34
Hello again,
Nobody having any opinion or any experience with distinguishing between LES and RANS activated regions in DES?
I would really appreciate your suggestions.
Turbulent Length Scale and Intensity for Airfoil shamim STAR-CCM+ 2 July 12, 2017 23:11
grid length scale in DES Spalart-Allmaras - definition of dTilda fsaltara OpenFOAM 9 December 11, 2014 04:48
Length scale in k-omega models? MaryBau Main CFD Forum 1 June 1, 2014 11:41
Modify length scale definition for DES Stephen FLUENT 0 February 26, 2005 09:06
Length scale was zero chris Siemens 2 September 10, 2001 09:12
