Multiphase simulation in FLUENT for rotating equipment |
October 18, 2014, 07:57 |
Azarbayjan-e Sharqi (East Azerbaijan)
Rep Power: 11 |
I am trying to model an predict the NPSHR in centrifugal pumps I wonder that is there any special model or way of defining boundaries for reaching some reasonable results.
October 21, 2014, 02:46 |
David Stanbridge
Rep Power: 16 |
There is no special way for this case. Just make sure that the grid resolution is fine enough to provide decent pressure profiles. The difference between the inlet pressure and the lowest pressure in the domain, in combination with knowing the vapour pressure of the liquid, should be sufficient to define the NPSHR.
October 21, 2014, 07:20 |
Thanks dear David
Rep Power: 11 |
I wonder if there is a model for visualization of vapor which are produced in cavitation phenomena...
Thanks for your answers |
October 21, 2014, 07:30 |
David Stanbridge
Rep Power: 16 |
There is a built in cavitation model within Fluent that you can use. You need to run a multiphase simulation but it will show vapour generation should you go below the vapour pressure.
October 21, 2014, 07:55 |
Thanks dear David
Rep Power: 11 |
Yes you are right, but I have tried some mutliphase models the run doesn't start...
If it is possible for you help me about the settings for simulating cavitation visualization in FLUENT for Centrifugal Pumps. |
October 21, 2014, 08:10 |
David Stanbridge
Rep Power: 16 |
Please refer to http://www.docin.com/p-392460303.html
October 21, 2014, 08:39 |
Thanks David
Rep Power: 11 |
It is vary nice & helpful tutorial...
I am going to study and let you know the results. |
October 21, 2014, 08:44 |
Rick
Rep Power: 26 |
Hi!
If you want to evaluate NPSHr, why you want to simulate cavitation? Pump must avoid cavitation during operation and so NPSHr is well above this limits. I think you should run single phase simulations: if you see absolute pressure <= vapor pressure, it's not realistic (in your case): this means that in these areas cavitation occurs, so you need to change boundary conditions to avoid it. Moreover, simulation of cavitation si not straightforward: all the models are "incompleted", as the terms in the source equations don't take into account all the members of the Rayleight equation, and this, in some cases, lead to converged solutions, but irrealistic results. Custom cavitation models can be implemented through udfs, but they require fine tuning with experimental data. Daniele |
VOF multiphase - Validity of Fluent ? | manxu | FLUENT | 2 | January 2, 2014 11:17 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Multiphase Simulation | dungsidietquy | FLUENT | 4 | November 4, 2009 13:46 |
New to multiphase fluent simulation, any tutorials | Camps | FLUENT | 0 | September 9, 2006 11:41 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
