Direction-1 and Direction-2 in porous zone
Like Tree3Likes
  • 2 Post By swiftaircraft
  • 1 Post By highhopes
Old   October 19, 2014, 15:39
Default Direction-1 and Direction-2 in porous zone
highhopes is on a distinguished road
I am having a hard time trying to figure out what Direction-1 and Direction-2 mean exactly. Could you please give me examples?
In addition, why are there differences in orders of magnitudes between components of viscous resistance and inertial resistance at different directions despite the isotropic media? I have seen this in some of the tutorials prepared for flow in porous media. For example, direction-1 component of viscous resistance has a value with order 10^7 whereas the other two have 10^9. Doesn't it matter even if I know those parameters for a certain porous medium? Where is the accuracy if I can manipulate the order of magnitude?
Thank you
highhopes is offline   Reply With Quote
Old   October 19, 2014, 18:26
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Thank you
Viscose resistance is actually the inverse of permeability and its value is different in different materials. This parameter in fact shows the magnitude of flow permeation in each direction. Of course, in isotropic material, this value is the same in all directions (say, x,y,z) but in some others, anisotropic permeability dominates and permeation is usually several order magnitude lower in one direction compared to the two others. So, based on your problem and model, you can takes it into account or just ignore it. the same definition is for gas diffusivity and thermal conductivity as well.
Hope it helps
Regard yours
A CFD free user is offline   Reply With Quote
Old   October 20, 2014, 04:44
Thank you for your answer but I still do not know the influence of the directions. If the porous medium is isotropic, are the direction vectors supposed to be the same and non-zero?
Old   October 20, 2014, 17:47
A-A Azarafza
I don't understand what exactly you mean. But if the porous media is isotropic, the values of the permeability are the same for all three directions.
Regard yours
Old   October 21, 2014, 02:41
David Stanbridge
swiftaircraft is on a distinguished road
highhopes, Direction 1 and 2 are defined in the same panel in which you enter the inertial loss factors. Usually Direction 1 is 1,0,0 (x axis) and Direction 2 is 0,1,0 (y axis). If the media is isotropic then the direction vectors should still be different. You will just specify the same loss coefficient for each direction.
David Stanbridge
Swift TG Solutions Limited
www.swifttgsolutions.com
swiftaircraft is offline   Reply With Quote
Old   October 21, 2014, 15:57
Thank you for your answers,
The only information regarding the directions is the one written under title "Defining the Viscous and Inertial Resistance Coefficients" in Fluent user guide. Is there any source clearly explaining how the direction vectors are used and what they are for? Is it basically about how they lie in the coordinate system? Or does it have something to do with the main flow direction? If so, doesn't any transverse velocity component die out even in porous media with very high porosities?
My medium is simply a porous cylinder whose axis is on x. Are the direction-1 and direction-2 vectors supposed to be (1,0,0) and (0,1,0), respectively?
Thank you again
Old   October 22, 2014, 03:34
David Stanbridge
Please refer to equations 6-1 and 6-2 in the Fluent Theory Guide 6.2.3.2 Momentum Equations for Porous Media. All of your questions are answered in the formulae. As you can see it will be a vector sum. For a porous cylinder then use the Conical option in the porous zone. Here you enter 1,0,0 as the axis vector, 0,0,0 for the cone axis (assuming that your cylinder has it central axis on the x axis) and then enter Direction 1, 2 and 3. For a cylinder the cone angle is 0. For the Conical option Direction 1 is tangential (i.e. along its length), 2 is normal to the cone surface (which is radial for a cylinder) and 3 is circumferential.
srsel6 and PrabhathC like this.
David Stanbridge
Old   October 23, 2014, 02:36
Thank you very much David.
sujaysuguna likes this.
Old   June 28, 2017, 02:23
wxn
sofina
wxn is on a distinguished road
The porous zone is sphere .How should I set the direction vector?
wxn is offline   Reply With Quote
Old   June 28, 2017, 02:32
David Stanbridge
You will need to have a custom UDF for this in order to define the relevant vectors around the sphere.
David Stanbridge
Old   June 28, 2017, 07:21
wxn
sofina
I'm a little confused.
How do I define the relevant vectors around the sphere by udf?
Hope you can give me more suggestions
Old   September 28, 2017, 14:08
Default solar chimney
  #12
pezhman
pejman_tork is on a distinguished road
i am trying to simulate the 2d solar chimney in fluent.
i want to simulate solar storage layer as porous medium.
what should i put for direction-1 vector X & Y?
pejman_tork is offline   Reply With Quote
Old   September 28, 2017, 19:00
A-A Azarafza
For defining porous media, you You definitely need the porosity and permeability of your of your model. For the permeability you can use experimental data or you can use start with fluent default values. If the porous media is homogeneous, Of course the baggies for pime ability in exam Y direction would be the same but if it's anisotropic, the values would be different. You need to consider it as well.
Sent from my SM-G950F using CFD Online Forum mobile app
Regard yours
Old   September 29, 2017, 09:54
pezhman
thanks for your quick respons
for viscoue resistance and inertia resistance i use the same value in both direction , but i dont know what is the value for X&Y direction for storage medium ,llll.JPG
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
FLUENT porous zone inputs eishinsnsayshin FLUENT 19 April 17, 2020 04:40
Porous zone input properties chaudhry_hashim FLUENT 0 September 10, 2014 02:48
Direction vectors and adsorption in porous zones Toplaa FLUENT 0 August 16, 2013 14:22
Porosity profile, dividing a zone, or getting zone location from zone khoopes FLUENT 0 June 2, 2012 19:39
