How do I wrap a complex part?
Old   November 1, 2014, 16:45
Default How do I wrap a complex part?
Mark
woodmark75 is on a distinguished road
I have a Solidworks model that I must perform CFD on in Fluent. The problem is that the model is made up of Both surface bodies & solid bodies.
I would normally just create the fluid domain (enclosure), & just do a boolean-subtraction. But as my model contains surface bodies, Design Modeler can't calculate a volume to extract.
Is there a way that I can 'wrap' the entire surface of the model? An example would be close fitting shrink wrap. This would give me a sealed volume to subtract. I'm working on version 14.0
Any suggections would be appreciated...
woodmark75 is offline   Reply With Quote
Old   November 4, 2014, 11:48
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Hi Mark,
Not sure what licensing you have, but check out Fluent Meshing. ANSYS did a great walk through on a youtube clip: www.youtube.com/watch?v=aLjJh41iwhM
Be aware that Fluent Meshing has quite a steep learning curve, and will seem quite unnatural at first if you are only used to ANSYS Meshing.
Stu
stuart23 is offline   Reply With Quote
complex geometry, surface & solid bodies, wrap
Complex Fields suniljain OpenFOAM 1 September 12, 2019 08:09
[Ansys meshing] Multibody part mesh ANSYS_user111 ANSYS Meshing & Geometry 0 April 3, 2014 05:51
Applying Loads to Part of a Surface/spliting a part in ANSYS 123catty456 Main CFD Forum 1 July 29, 2013 12:52
Complex scalar fields JamR OpenFOAM Programming & Development 0 July 15, 2013 11:29
icem hexa - load different blockings for each part of geometry??? Catthan ANSYS Meshing & Geometry 2 May 28, 2010 11:27
