November 2, 2014, 12:54 |
Error with writing buffered file
Ondrej Novak
Rep Power: 12 |
Hello
i m having this problem. It does not happen when i run simulation first time but when i re-run it it occours. The mesh is still less big than sometimes i run, so it should not be running out of memory. I also have enough space on hardrive (13gb, my simulation takes no more than 9Gb and it has its space reserved) Error is: Error at Node 0: Buffered write, in function allocate_mem_buffers: unable to alloc memory (247268616 bytes) for mem_buffer->mem_buf. And then error writing " FFF_Setup_output.cas.gz" MPI Application rank 0 exited before MPI_Finalize() with status 2 Error object: (rp-var-value "dmp/unsteady-tracking?) Thanks for suggestiong and solution Regards |
August 13, 2015, 00:58 |
same problem got any solution ?
Sai Praneeth M
Hi there,
I'm facing the same problem now, can you let me know what you did to solve that ? thanks |
April 4, 2021, 00:00 |
Iharshavardhan reddy
Rep Power: 5 |
Hi
I am also facing a similar problem can you tell me how to resolve this? Thanks in advance. |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
