Is convergence criterion (residual value) related with grid size?
Old   November 3, 2014, 00:14
Post Is convergence criterion (residual value) related with grid size?
rdeepakkumar is on a distinguished road
Please, i need a clarification. Is convergence criterion (residual value) related with grid size? otherwise on which basis we choose the convergence criterion?
rdeepakkumar is offline   Reply With Quote
Old   November 5, 2014, 21:59
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Cell size doesn't go directly into the calculation of residuals.
But different mesh arrangements will give rise to different solution fields which can change eventually cause different residuals to be calculated. Hopefully the difference is small so that the mesh dependency is negligible.
LuckyTran is offline   Reply With Quote
Old   November 9, 2014, 01:19
Thank you so much for your valuable time..
may i know how the different discretization scheme (order of accuracy) relates with while taking convergence criterion (residual) value. can u elaborate..
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 19:31
rhoSimplecFoam Mach0.8 no pressure values CFDnewbie147 OpenFOAM Running, Solving & CFD 16 November 23, 2013 05:58
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
