Is convergence criterion (residual value) related with grid size? |
November 3, 2014, 00:14 |
Rep Power: 14 |
Please, i need a clarification. Is convergence criterion (residual value) related with grid size? otherwise on which basis we choose the convergence criterion?
November 5, 2014, 21:59 |
Lucky
Rep Power: 66 |
Cell size doesn't go directly into the calculation of residuals.
But different mesh arrangements will give rise to different solution fields which can change eventually cause different residuals to be calculated. Hopefully the difference is small so that the mesh dependency is negligible. |
November 9, 2014, 01:19 |
Rep Power: 14 |
Thank you so much for your valuable time..
may i know how the different discretization scheme (order of accuracy) relates with while taking convergence criterion (residual) value. can u elaborate.. |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
should Courant number always be kept below 1? | wc34071209 | OpenFOAM Running, Solving & CFD | 16 | March 9, 2014 19:31 |
rhoSimplecFoam Mach0.8 no pressure values | CFDnewbie147 | OpenFOAM Running, Solving & CFD | 16 | November 23, 2013 05:58 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
