how can i perform surface suction or delaying boundary layer separation? |
March 22, 2019, 07:46 |
sirak masresha
Rep Power: 8 |
hey friends, how are you doing? if you don't mind, i need your help. i am studying flow over an aircraft wing to (improve) increase the lift at high angle of attack by delaying boundary layer separation on the method of suction on the wing upper surface and near to 3/4 chord, then i need to simulate the flow analysis by using ANSYS fluent, and what are the procedures and the step?
April 22, 2020, 04:28 |
Rep Power: 10 |
I am working on boundary suction currently. May I ask a few doubts? Were you able to complete the simulations? Can you please explain the simulation set-up, the boundary conditions of the suction surface in particular. Please spare some time and make your reply. Thanks in advance. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
